Disables redistribution of routes to OSPFv3.
| direct | Specifies direct routes. |
| ripng | Specifies RIP routes. |
| static | Specifies static routes. |
| isis | Specifies IS-IS routes. |
| isis-level-1 | Specifies IS-IS Level 1 routes. |
| isis-level-1-external | Specifies IS-IS Level 1 External routes. |
| isis-level-2 | Specifies IS-IS Level 2 routes. |
| isis-level-2-external | Specifies IS-IS Level 2 External routes. |
| bgp | Specifies BGP IPv6 routes. |
| e-bgp | Specifies EBGP routes. |
| i-bgp | Specifies EBGP routes. |
The default setting is disabled.
Use this command to stop OSPFv3 from exporting routes derived from other protocols.
The following command disables OSPFv3 to export RIPng routes to other OSPFv3 routers:
disable ospfv3 export ripng
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
